Ken Roach
Hi guys,
I'm an absolute beginner with G3 terminals and Crimson, coming from a deeply PanelView background. I plan to use a G308 terminal.
A couple of months ago I got some great advice on data logging in PLCTalk Thread 442419.
The project cooled off, and now it's hot again.
And now there's another feature I need, that's the opposite of data-logging: I want to browse a directory on the CF card and select a *.CSV file, and then parse each line and the place each value into a Data Tag in the G3, which in turn will write a value to a CompactLogix. There will only be twelve items of data.
The files will get to the CF card via FTP, manually placed there by the customer using a nearby laptop.
I found some nice Crimson 2.0 scripts written by KP_EENG in this thread (PLCTalk Thread 54225) that I will base my "recipe read" program on.
As I understand those example Programs, I need to make the file name part of the program or enter the filename as a String on the terminal.
What I'd prefer is to be able to browse the "recipe folder" to select the file by tapping on it from a list of files.
While I'm busy Reading the Fine Manual, can anyone tell me the basics of how this sort of function could be implemented in Crimson 3 ?
Is there a "select a file and when the user clicks on it run a specific program" object or primitive ?
