How to start SIEMENS from CMD?
HolaHola
Jun 2016
CA
SIEMENS TIA Portal. Is there any feature to run the software from CMD ( Command Prompt of windows ) ?
How ?
Thanks.
CMD program start
In windows 7 the first quotations will be the title to the CMD window to open the program.
Start "title" "C:\path\program.exe"
Formatting your command like the above will temporarily open a CMD window that goes away as fast as it comes up so you really never see it.
Formatting your command like that also allows you to open more then one program without waiting for the first one to close first.
Any program can be started from the command prompt, as gartut said.
However, I don't think it takes command line flags. If you want programming access to Portal, ask your Siemens rep about "openness".
Easiest way is to make a shortcut to portal and call it "portal".
Put that shortcut in your c:\windows\system32 folder. Then you can just press the windows key, hit R and type portal and press enter.
The exact folder may depend on your operating system, there is also a way of doing this through the registry.
Hi All, I'm new to Siemens PLCs. I have a device that have a Siemens 1515SC IPC ruining the control and HMI applications, its documentation...
1,703
Hello everyone, I've been doing projects with Siemens and Rockwell PLC's for a couple of years now, and some softwares really helped me alot in...
2,646
Its a S7-200 part # 6ES7 216-2BD23-0XB0 A customer sent me one of these to extract the program out of. I have zero experience with Siemens S7...
2,236
Hello, my friends, I want to increase my experience in the PLC and I started to think about buying Siemens Start Kit to create a platform for the...
2,316
Hi, I have a G120 PM140 IP20 Power unit with a G120 CU240E-2DP Control Module driving a 45KW motor with a fan directly attached. The fan is in...
2,376
