how to write a program for Siemens S7 300 touch-screen
ersinist
Jun 2007
Sofia
Hi everyone,
For my diploma project I have to create a menu on a touch-screen. Could you tell me how I can write a program for touch-screen of Siemens S7 300? I heard that Flash is used for the interface but I don't know the details. And I want to know if I can simulate this program using PLCSIM simulator in Simatic Manager.
All helps are welcome, thanks in advance.
Well, you're going to have to get some details...
There is (to the best of my knowledge) no "native" S7-300 touch screen. BUT there are many, many different possible touch screens that will work with the S7-300. How you program them will depend on which one you are using. I'm not aware of any commercial products that use flash, but there may be.
So, if you want a good answer, you're going to have to give us some more information.
And, since it's homework, you could go ask your instructor. Surely you've covered this type of information since it's in class. They don't usually leave you hanging without either providing the information directly or indirectly leaving you a path to the information....
hmm.. actually this is just a part of my project. And this is my final year project, anyway... I couldn't find the instructors last week, when I find them I will ask.
thanks
Adobe Flash is not used in any of the HMI panels that I know of, and not in any of the PC based HMIs that I know of. I doubt there is any HMI software that uses Flash.
With Siemens Protool or WinCC Flexible you can connect to PLCSIM.
We are using MP270's and are currently using Protool but will be moving to Wincc soon. They may be referring to the OS which is Windows CE or the fact that there is a compact flash port on the panel.
Robert
A little vague on what is meant with "Flash" and "interface". It could be a Compact Flash card in a CF slot ("interface" if you will).
Or it could be Adobe Flash animation.
If he means the 1st, then indeed for OP270 there is a CF slot where you could install an ethernet CF card to put the panel on ethernet. BUT, today it is near impossible to locate an NE2000 compatible CF card. So it is not really an option any longer.
If he means the 2nd, then you could propably install a Flash animation OCX on the panel. BUT the graphics capabilities of the panels are so little that the end result will be horrible.
That panel has a resident ethernet port.
Robert
OP270 no. OP277 yes.
edit: The reference to "flash interface" made me think that he possibly was referring to CF ethernet card that you coould insert in an OP270 with a CF slot.
The newer panels have MMC slots in stead.
Ooooops.. Sorry, I was thinking the MP series. You are absolutely correct.
Robert
PS. I wish someone could tell me how I can do something with the resident ethernet port on my MP270. Guess I need to start a new thread instead of jacking this one.
Well, they are great for backup/restore and not for anything else. It should be possible to insert a CF ethernet card. But the downer is that all the manufacturers of the NE2000 compatible CF cards have stopped the production already.
D**n, I should read before I write. I didnt notice you wrote ethernet port and not CF slot.
There are lots of things you can do.
Some suggestions:
Downloading via ethernet (recommended).
Datalogging to a network drive or an ODBC database
Remote control via the sm@rtaccess and/or sm@rtservice options.
And of course, connecting to the PLC via ethernet.
Some suggestions:
What I would be happy with is being able to display my HMI on our plant network. I have a port inside the panel. They should have put some sort of web server in these things.
Robert
You should look into the sm@rtservice option. Your MP panel should be perfect for this.
It makes the panel act as a webserver that you can access from LAN or WWW.
Notice that when you do use the webserver access, you actually take over the panel from the remote location. The web server does not work transparant.
Hello everyone, We have a PLC Omron CJ2m CPU12, it contains an old program and it is UM read protected by password. Now we have a new program...
534
Hello friends. I need to write a program. This is exactly what is asked of me: When Sensor 1 and Sensor 2 give output, it will allow Robot to...
956
I am trying to import and overwrite program while online with a 5570. I swear you can do this with a 5580. I even tried inhibiting the program...
1,072
I just finished writing my first program! Well PLC program anyway. I used to do a little programming when I was a kid working thru manuals on my...
2,843
Hi guys, I've taken on a new client, rural water district. They have an ancient system, with Scadapacks and NI Lookout. Some of their...
1,773
