How to zap a password on Omron CQM1 CPU21?
gregblack
Jul 2004
Somebody has put a password on our Omron PLC, meaning we can't download a new program or online-edit. We tried disconnecting the battery with power off and leaving it for 30 minutes (we have the program backed up) but found the password and program still intact on power resumption.
Also, does a backup of the program save the values of data registers or are they reset to zero on uploading a backed-up copy of the ladder logic?
Thanks for any help.
you will probably have to leave the battery dissconnected for more than 30 minutes. The capacitors hold a charge for a long time.
There is a way to drain them by grounding a certain terminal but i would not know. I ran into the same problem on a AB slc5/01.
the replies i got told me to remove the battery and wait for up to 2 weeks for the cap. to loose there charge, not what i wanted to hear,
but then someone posted a more helpful suggesstion
1) When prompted for the password enter MLCLRMEM , using the keypad of a
telephone you must translate this into its numeric equivalent of " 65257636
i entered those numbers and voila! it worked.
sorry this does not help you but maybe there is something like that for omron..
mark
Thanks for the help. Got onto a more-informed-than-the-first Omron rep (the first claimed it was impossible to remove a password) who was puzzled that the download would get to 99% before giving a "Program is password protected" error. He suggested checking the write-protect DIP switch, which did the trick after a reboot ie it wasn't password protected at all. Love those spurious errors, they make work that little bit more challenging :)
I can see you never tried this one. The standard method for "clearing the password" is "CLR","MONTR","CLR".
I can just see the support calls now.
yup tried it and it worked
it was a slc 5/01 out of a medar control panel.
medar had set a password so nobody could screw with the program.
when i was prompted for the password i entered the numeric numbers
65257636 which allowed me to do a download on top of the old program,
it clears the password, program and the memory.
does no good if you just want to get rid of the password but if you want to reuse the slc in anouther application it is perfect.
i guarantee it works, did for me.
mark
Hi All, How do I set a password to PLC using Proficy machine software 9.5-9.8 or some other way? I as using Emerson CPE305 CPU. Thanks.
368
  • Locked
  • Sticky
Hi folks, If you're having any login issues kindly send an email to [email protected] or use the 'contact us' link on the bottom of every page to get...
1,124
Hello is their a way to create a password that contains the following variables: 1) number of the day in the month, example 07 the 7th day in...
730
Hi, Bit of a newbie here to Siemens - I just bought an old S7-1500 off of eBay and the PLC/card is password protected. I have no idea what the...
1,024
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,299
