Hows this for a new VFD install
padees
Aug 2011
Michigan
908
Little PF525 was wired in and set up to run on power up. Disconnect for this is over 200 feet away.
See the reversing starter? Yep, that is how they go from forward to reverse on this conveyor.
I gotta fix this, but thought someone might like a chuckle.
Halfway decent wiring job at least... wonder why they didn't use a drive input to toggle the reverse o_O
Decent wiring should work fine
using the drive to reverse and motor overload is much simpler then using a reversing contactor and way cheaper.
one thing you said that disconnect is over 200 ft away.
what is the distance from the drive to the motor ?
I believe code requires the disconnect to be located within 50 ft and in line of sight on all motors with very few exceptions. that's part of the lockout - tag out requirements.
most places require a disconnect at the panel for maintenance to work on it.
I didn't mean to burst your bubble but we all need to try and bring upgrades into compliance when we can.
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
341
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
254
On the HMI-1200, the Wall clock date shows "1/4/1970". How can I correct this? Can't seem to find where this date is coming from or how to change...
908
All - I don't know much about PLC5, I am more from ControlLogix. Can someone answer this: So I am looking at a N262:10 tag with offset 2...
1,152
Hey everyone, Trying to connect to a 5069-L320ER compact logix over USB for the first time. RS Linx Classic can see the controller just fine, but...
1,227
