HSC configure for flowmeters
Jorge A.
Aug 2022
Nuevo Laredo Tamaulipas
Hi Guys:
I have a question i am trying to config a hsc on CCW Micro 850 to measure the pulses for two flowmeters.
Do i need to use two hsc`s to read the pulses or i can do that with only one hsc?
Kind Regards.
You really need two. Theoretically you could put them together on one as long as they never flow at the same time and you knew which one was flowing, but that would be a kludge.
Depends a lot on the type of flowmeter and you'd still need to put something in between to choose which flowmeter was pulsing so that they'd be isolated from each other.
Do you have spare digital outputs?
I don't think it's a good solution (it definitely is not), but could be what's possible so long as your customer understands the limitations and potential issues that come with it.
I have 1756-HSC which has to be reconfigure during operation using Ladder. I have read user manual 1756-um007A-EN-P which is published in October...
1,357
Hi All I've read the manual...didnt understand much... I have a accurate flow meter that gives pulses with certain width. just have to obtain...
2,977
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
99
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
180
Hi everyone, this is my first time trying to setup encoder counts and track the traveled distance and speed i am using L27ERM QBFC1B processor...
393
