HSC/HSL Encoder Help on a Micro1400
kstiles1499
Nov 2022
St. Louis, MO
Hi everyone,
I have a Micrologix 1400 using an HSL instruction (High Speed Counter Load).
This instruction is used in junction with an encoder input to compare a motor's position with the HSC's .ACC value.
I am having a hard time finding what controls the HSC0.acc value, as sometimes this value is counting up, down, or zero. When using cross reference, I was able to discover some MOV's and a RAC (reset accumulated value) which answers the question of why the value is sometimes zero.
Also when cross referencing, I see several HSC:0/DIR bits. I know this is 'count direction' bit, and changes states when the counter changes its count direction, I just don't see what is controlling that transition.
Is this instruction somehow tied to a real input? I have viewed the 'function files' and I really don't know what I'm looking for, as I don't know what is making it count. I see that the Program File is "42" however ladder 42 is completely empty. I was also thinking that the HSL just counts as long as its subroutine is being scanned, but it is being jumped to right off of LAD 2 MAIN, so I believe it is always being scanned.
Also, I'm not sure if it's against the rules to post the .RSS file, but if it helps anyone help me, I would gladly do so.
Pictures are attached, and any help is greatly appreciated!
Screenshot 2023-07-23 183202.png Screenshot 2023-07-23 183327.png Screenshot 2023-07-23 183416.png
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
63
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
169
Hi everyone, this is my first time trying to setup encoder counts and track the traveled distance and speed i am using L27ERM QBFC1B processor...
391
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
460
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on...
361
