HSC on ML1100
In your posted file you haven't reset the input filters so your input pulse will have to be very slow to show up.
You are using mode 7 (HSC Mode 7 - Quadrature Counter (phased inputs A and B) With External Reset and Hold) which ties up the first 4 inputs. Please read the documentation thoroughly.
Bernie,
Thank you! I have a bad habit of ignoring things i don't understand, but RTFM is pretty clear. The mod 7 was an error that was changed back to mod 0. It was probably only at mod 7 for a few minutes and that is when i made the zip. As for the BWA base definition, it was obvious after i read about "input filtering" on p25/p26 of 1763-RM001C-EN-P, and everything was grey until i defined the base unit correctly. Then, finally, i could choose 25 microseconds for ch 0-1.
I am not sure that it answers my question about why it didn't work before and does now, but sometimes those questions never get answered.
narlin
Hi all, I need to implement a flow meter via HSC in an existing machine. The flow meter provided is a hall effect NPN unit, which needs to connect...
3,848
Question about using the HSC with a ML1100. when the program is running, does the value of HSC:0.ACC update only at the beginning of the scan or...
42
8,168
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
77
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
179
Hi everyone, this is my first time trying to setup encoder counts and track the traveled distance and speed i am using L27ERM QBFC1B processor...
392
