Hsc
Mar 2005
49
Hi
Specs:
MicroLogix 1500, 1764-24BWA series B revision A
Processor unit, 1764 LSP series B Revision C
Starter version of RSlogix 500:
Problem:
I have 2 BEI encoders. All I want to do is position comparison.
Both encoders work but when I try and change the input filtering for HSC1 the lowest value is 500us. HSC0 allows a pulse width of 25us.
Everthing I can find to read says that all micrologix 1500 have 2 HSC's with an input ability of 20Khz.
Is the revision I have somehow different? Is the started version of 500 giving me problems?
any ideas?
Thomas
I should have included the version number of my software....6.2
There is a known bug with this software regarding HSC1. The solution is to either upgrade ur software or go the advanced configuration and under "generic extra data config" change the 3 and 4 word to 1.
The default is 5 I think. This setting recognizes a pulse width of 25uS.
U will notice when u move to the embedded I/O configuration that the filtering for inputs 4&5 and 6&7 is now 25us. The choice still does not show up, but it works.
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
126
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
186
Hi everyone, this is my first time trying to setup encoder counts and track the traveled distance and speed i am using L27ERM QBFC1B processor...
399
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
484
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on...
377
