I cannot activate RSView SE
elmauz
Dec 2006
Jakarta
Hi all..
now i have project with AB Controllogix and RSView SE. I have problem when installing RSView and move the activation from floppy disk. After install and move the licence, the RSView SE still on Demo mode..Whats wrong with that? Before installing RSView, of course Factory Talk and RSLinx has been installed. Are RSLinx need activation too?
Hello elmauz;
Try this: shutdown the RSLinx program before you try to move the activation (right-click on the RSLinx icon on the right side of the tool bar on the bottom of your screen, next to the time display).es when my licenses refused to transfer. RSLinx will restart automatically when you start a program that requires it.
Hope this helps,
Daniel Chartier
tnx Daniel..
I've try your suggest. RSLinx on my computer is not activated yet, so it is Run as Runtime Services. After STOP/Shutdown RSLinxNG.exe, and Run RSView Studio again, and choose Machine Edition product. the RSView ME still show as Demo mode. The licence i have are for RSView SE Station 100 Displays and has moved to the computer. Why RSView still didn't recognize the licence? Demo mode also show when i choose RSView SE Stand-alone. In my friend computer the licence Recognize and Run normally, are this is because His RSLinx Enterprise has activate before?
note: I use RSView for Versaview 1500w.
There is two activation avaliable for rsview sE server & client actvation which key you have moved rsview se studio is showing demo mode?
Rs view se studio key ----RSV.STUDIO
Rsview se client runtime key 100 pages---- RSVSE.100
Rsview se server 100 pages ---- RSVSESrv.100
i have this :
demo mode occurs in Machine edition and SE Stand-alone Edition.
It's confusing, isn't it? Let me try to summarise:
RSView Studio is the product that creates RSViewSE/ME applications. RSViewStudio ME is just for ME, RSViewStudio SE can do both.
RSViewSE Server actually runs the SE application that you create in RSViewStudio SE but it has no user interface.
RSViewSE Client provides the user interface for the application running on RSViewSE Server.
In order to get these products fully functional you load them from your CD and then install an activation onto your PC(s) (All the components can run on the same PC or all of them can run on different PCs).
So far so good. The confusing part is that the software also has a "Demo Mode" which allows you to use it (with various restrictions) before deciding if you want to buy it. The demo mode is what you get when you load from CD but don't put an activation on the PC. The activation that you've put on is for an SE Server and it won't "turn on" your RSViewStudio; RSViewStudio is therefore forced to run in Demo mode.
All you've got to do is spend some more money.........:cry:
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
131
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
171
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
674
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
200
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
341
