I need Information!!!
Nov 2008
Lahore, Pakistan
hello,
i need information on PLCs & there HMIs.
Actually, i am working on GE-Fanuc plc, & i want to configure it with the AutoLink software, that supports ASCON plcs.
But, the problem i am facing is that whenever i try to connect GE-FANUC plc with AutoLink, it says that" NO DEVICE DETECTED".
But as far as i know, both the plcs should work on the AutoLink.
Please let me know if there is any solution, or if i am doing it wrong.
As far as I am aware your autolink is not a compatible product.You need to buy GE Fanuc Proficey Machine Edition to do this, and dont forget the programming lead also.
You may get away with the older Logicmaster software if the PLC is a few years old.
Edit....
I see that this is SCADA software you are trying to configure.. Is it set up for Modbus comms because the brochure does not list GE Fanuc drivers.
Hi i have just been asked to upload a plc program from 1511-1 pn it has v15 firmware 2.6 the machine oem doesnt support the machine i got...
2,637
I am communicating with AB PLC through Ether net and able to read the N words. Want to read B as words but not able to read them as words. Has to...
1,926
I need help to install PCS-7 ES/OS Ghost copy on new and upgraded Simatic PC . While trying to load ghost on new Simatic PC , but Pc could not...
1,905
I need to communicate siemens S7-300(CPU 313C) to a mitsubishi HMI that supports MPI. I have search a lot on net but couldnt find information...
3,685
Hi everyone, I'm first time posting here. I would like to know if any of you have any lead or information that I can use to get information on...
2,585
