If the 1756-L71S is not in your local chassis, you need to add the Ethernet Module which you will be connecting through first. Remember, you are not connecting the two controllers directly, they are connecting through Ethernet. So if the remote chassis has a EN2T, you add the EN2T to your tree first, then you add the L71S under the EN2T.
