Studio5000 v34: Not able to connect to PowerFlex 7000-2E in tree.
ChaseV
Jan 2021
Minnesota
25
I have two of the same PCs and one can connect to my drives through the studio 5000 v34 program and the other PC can not gets the Error posted in the image.
Possible corrupt module definition in the project.
Delete the drive from the project then re-create it online and upload all drive parameters.
Would there be a way to do this with out having to do a download to the PLC. Hard to get the approval to do that. I have tried deleting it out of the tree offline and re-adding it and get the same popup.
Are you using FTLinx as your communication software? I had a very similar issue that was resolved by resetting my FTLinx configuration. Unfortunately that also reset the 30-40 drivers I had configured, which was a pain, but it fixed it at least.
The steps are listed in technote BF1603 (techconnect required).
If you don't have techconnect, reply with your OS details (which OS and 32/64 bit) and I'll extrapolate the relevant details from the technote for you.
@KuulKuum I tried bring the working file over and still didn't work, Have Not tried reinstalling or repairing Studio 5000 yet.
@ASF I am connect with the program with RSLinx still. Think I should try FTLinx?
Worth a try. Although now that I think about it, I *think* the drive browser uses FTLinx regardless of what communication software you're using for the controller connection. So resetting FTLinx might help regardless.
By the gods.
I'm not trying to pimp my own horse out, but this is where GENERIC shines.
OP: Your options are generally: a) reinstall or install updated AOPs, b) reinstall Studio 5K in its entirety (every version), or c) both.
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
154
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
164
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
226
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
369
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,684
