ICOM SLC Logicistics 100/150 Software
Steve Crotty
Apr 2002
Kingston
202
I need to upload a program from an old SLC 150. I found some software from ICOM SLC Logicistics (V2.09). My laptop is running WinXP Pro, and I seem to be able to open up the software and navigate, but I dont want to get to site and find out it wont work. Does anybody know about any issues running this software with the dos emulator in XP? Is there a better software I should be using?
My Comm kit will include a 1745-PCC and 1745-C1, which I think is correct, the PLC has a Large DIN style connector on it.
Any other "gotcha's" about the SLC 150 would be appreciated too.
Thanks,
Find an older computer, if possible, with a real RS232 serial port and with windows 98 second edition or older to take with you as a backup plan.
I seconed what jrwb4gbm said about the RS232 port. The 1745PCC is not going to work with a USB to serial adaptor. And the SLC100 software wants to directly manipulate the serial port, something WinXP will not let you do, even in Win98/DOS compatability mode.
Ths SLC150 is a really old PLC and it has a much simpler instruction set than the SLC500s. It does not use I, O, B, C, T, N files. 7xx addresses are internal bits, 8xx are specialty instructions 9xx are timers and counters.
Here is a link to the manual on the AB web site. Download it.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1745-um001_-en-p.pdf
OK Time to jump in the way back machine. Dusted off my old Dell with a serial port and dug out the PIC. Got the ICOM Logistics software up and...
1,707
We are using some old DOS software with an AB SLC-500 plc. The software enables us to upload/download the programme, but we don't see how we can...
25
5,191
Can someone tell me if it is possible to convert a file that was developed using the SLC Logistics software by ICOM to an (*.RSS) file that can be...
7,125
Hi folks ! Got an older Modicom BM85 and I suspect that it's not passing data to ModBus+ network. We had a power loss for a few days and I suspect...
70
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
428
