IDEC WINDLDR Rung Question
locotumbler
Jan 2013
Otsego, MN
98
I am trying to reverse engineer a code in a machine we have. I am doing this to understand the operation of the code to troubleshoot a problem.
the rung appears to be rather basic
it has a normally open contact followed by a series of 6 100 msec timers. this rung does not have any output coil of any kind so it does not complete across to the right vertical line.
my question is this.
Will all the timers start at the same time or will they fire sequentially? such as timer 1 finishes timer 2 starts and so on. if needed i can upload the code.
Thank you and happy coding.
Looking at the Idec WinLdr Help files, and also testing with a sample rung, your example is valid logic. Each timer triggers the following timer, in sequence.
Hello guys, Does a watch table or something similar exist? Thanks
1,204
Hi, we have an IDEC Micro3 FC2A-C16A1 PLC from which we need to get an upload. Is anyone able to confirm that WindLDR is the correct software and...
2,798
I have modbus RS485 reading into device address on IDEC PLC. The data same with what I get from Allen Bradley PLC.(-32768,17437) I can monitor...
4,224
I am trying to upgrade my IDEC software package. IDEC.com seems to be down. Does anyone know of a mirror site for them?
1,416
Have old F2AJ plc to replace with FC4A upgrade. Chatted with Idec and researched manuals to find no solution. Opening "Workfile.LAD" file with...
1,833
