IEC Contactor Terminal Numbering
DTan
Apr 2010
MN
Can anyone explain the system behind the numbering of terminals on IEC style contactors, motor circuit protectors, and overload relays (ie, AB 100-C, 140-M, and 193). I understand that on a starter, 13 and 14 are a normally open contact, 22 and 23 is a normally closed contact, and on an overload relay 95 and 96 are a normally closed contact, but what is the coding behind these numbers? From what I've gathered, the first number is a group and the second is related to function, but are there any rules on what number is used for a group? Is an overload always 95 and 96, or could it be 22 and 23 since it's nomally closed?
Most overload relay i have encountered in any brand the 95 and 96 is normally closed and 97 and 98 is normally opened.
I dont think so or maybe they are using only to identify these numbers.
Thanks...
I'm looking for a definition of AC1, AC# and AC4. I've Googled without luck.
9,081
I am trying to deal with fragmented data, and have been getting stuck. So far I am able to command the Fuchs VE Software version correctly and I...
166
Hi all, I am getting back to using IEC for schematics and was wondering about the 81346-2:2019 codes. What does everyone use for a diffuse...
564
I just took a skim through 81346-2:2019 and was wondering which codes you all used for Safety devices like Safety Controllers, EStops, and guard...
565
I know this is a PLC forum but there are many people from around the world that might be able to help me. I have an aspect question (IEC). I am...
20
2,013
