IM151-8 PN/DP / ET 200S Questions
Pete_S
Mar 2015
Portland Maine
76
I am looking to procure an ET 200S with a IM151-8 PN/DP module to perform some testing and potentially enhance our product and I was hoping some users that have experience with this hardware could answer some questions for me:
1) Is my understanding that this is a turn key piece of hardware correct?:
https://www.ebay.com/itm/Siemens-6E...AOSwvTpaH4qO:sc:FedExHomeDelivery!02118!US!-1
2) My understanding is the most common user story with this hardware is as a Remote I/O drop. My research shows that the IM151 module in essence has a S7-314 CPU. Do any users know if TCP/IP communication to the S7-314 possible through the ET-200 ethernet ports in this user story, IE so an OPC server with a Siemens driver could hit the module directly rather than through the parent S7 controller that has this hardware configured as a Profinet node?
3) Does answer to #2 change if the programming is done in Step 7 Classic vs TIA Portal?
Thanks!
1. ET200S and SP are remote IO.
- Both have IM (interface modules) and also CPU modules
IM151-8 is full CPU (basically 3xx series if you look specs, it is on different package and have less memory. CPU have profinet and profibus is possible with separate DP card
2.
-If you have only IM module, then you need some separate CPU for controlling remote IO Modules
(Profibus or profinet both works, but there are different IM modules for these)
- If you have CPU module from ET200s range, then OPC is possible like on 300 series
Pete
That is a cpu
You can program it with Step 7 or TIA Portal
From the pic, you will need some IO though
Either profinet or IO modules that mount on the right side of the cpu
Pete
That is a cpu
I am only interested in validating ability to access PLC tags and DB's that reside on the 314 CPU using a Siemens TCP/IP driver connecting to an OPC server, I don't actually need I/O as im just banging bits not running any real process. So sounds like if I ensure the protection setting are such to allow PUT/GET messaging (TIA Portal Programming) then I should be able to communicate directly through the E200 rJ45 ports?
We have these in our shuttles. The IP Address is stored on the SD card for the unit. We had a card go bad and I am trying to copy another card...
1,155
Dear Colleagues, I am struggling with configuring the comms between G120 VSD and IM151-8 CPU over the Profinet. I have set the addresses and...
2,233
Good evning, Today i was going to add a new profibus nod to a system it´s a 6ES7151-1CA00-3BL0 Siemens ET200s IM151-1 comapct. The module have...
2,233
Is there any other option to talking/programming a stand alone ET200S with IM151-7 cpu without buying the $500+ USB-to-MPI adapter?! I got the MPI...
3,122
I can't find a option to make my 151-7 configuration connect to the MPI network in Netpro. It shows a Profibus DP at 3, but I can't connect the...
2,831
