im308c and s5 155u(cpu948)
nadakotb
Apr 2009
EGYPT
i have an old PLC : S5 155U (CPU 948)
i need to connect it to ABB PLC using Profibus-DP, ABB will act as Master and S5 as slave.
I need to know how to do the following :
1- Install IM308C in the same rack with CPU 948
2- Configuring IM308C to act as slave for another PLC (ABB in this case, it doesn't matter anyway)
3- Accessing Memory area of CPU948 from ABB PLC
can anybody thankfully help me in this?
aiting ur reply
I am not sure if this will help you or not. Sounds like you already have purchased some of this but if not...I bought the below unit and installed it beside an old PLC 5/04. I made the connections and was easily able to connect up using the ethenet. This unit has drivers that allows you to connect up to almost any kind of PLC or protocol and was less than $500! I was supprised to get this working but the tech guys will help you with what ever you need. There number is
US (800) 422-7044
Here is the unit I bought = XSDRIN-02 Lantronix Gateway for Allen Bradley DF1 to Ethernet
unfotunately i have already purchased so
can any body help me about
Hello All, I am looking for a version of FB IM308C (FB 192) for release 2. I have only managed to find a version that will work for release 6. I...
1,901
Hi all, could anybody confirm if is possible to communicate over IM308C (S5-115)by PROFIBUS DP protocol to InTouch SCADA (PC side CP5613A2 card...
1,750
I have the following problem on this sistem . The master is s7 400 , slaves are connected to profibus , there are three slaves , a s5-95 from wich...
2,694
I need to connect an S5-115U to a MP370 using a current loop connection (tty) using a S5 AS511 connection ? I was wondering if I have to...
4,293
Hello collages, There is a system which configured S5-155U cpu948 and 6 pieces OP25's and communicated with profibus dp (IM308C).I want to change...
5,306
