IM308C to InTouch Communication
BoSChoW
Apr 2006
Nova Gorica
107
Hi all,
could anybody confirm if is possible to communicate over IM308C (S5-115)by PROFIBUS DP protocol to InTouch SCADA (PC side CP5613A2 card, SIMATIC NET 6GK1713)
Thanks for your support,
best regards,
BoSCHoW.
It should be possible in Master-Slave configuration. For ex. CP5613 as DP Master and IM308C as DP Slave. In this case you can exchange about 244 bytes In/Out between CP5613 and IM308C. You have to check if InTouch can use DP Master functionality of CP5613. Additional programming from S5 side is also required for data exchange.
i have an old PLC : S5 155U (CPU 948) i need to connect it to ABB PLC using Profibus-DP, ABB will act as Master and S5 as slave. I need to...
3,023
Hello All, I am looking for a version of FB IM308C (FB 192) for release 2. I have only managed to find a version that will work for release 6. I...
1,908
I have the following problem on this sistem . The master is s7 400 , slaves are connected to profibus , there are three slaves , a s5-95 from wich...
2,705
I need to connect an S5-115U to a MP370 using a current loop connection (tty) using a S5 AS511 connection ? I was wondering if I have to...
4,304
Hello collages, There is a system which configured S5-155U cpu948 and 6 pieces OP25's and communicated with profibus dp (IM308C).I want to change...
5,320
