Configuring connection between IM308C (SIMATIC S5) and OP270 panel via Profibus DP
tulip
Oct 2005
ist
236
Hello collages,
There is a system which configured S5-155U cpu948 and 6 pieces OP25's and communicated with profibus dp (IM308C).I want to change
this OP25's one by one with a new one OP270's.How can ı configure?
Has anyone out there had any experience with ?...
If you are using Protool, open your project and select "Convert > Start". Pick the OP you want. I would reccomend using the 10" or the largest screen, so there are less screen size errors. The converters work quite well.
I dont understand why you would want to convert from a 6" screen to a 10" screen. In particular bitmaps can become stretched in an ugly way.
Also, the new OP270-10 wont fit into the panel cutout of an OP25.
I don't remember him mentioning the size. But what ever! Try both and look at the Protool to see how it looks. I have had problems with resolution and when I went to a larger screen, it looked better.
Is it possible to configure FTV and rslogix 5000 to communicate with a controllogix PLC using the same DF1 connection?
1,826
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
779
Hello everyone, I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a...
593
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
661
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,156
