Implement fetch/write on s7 315-2 PN/DP
bullegrim
Sep 2006
Sundsvall
The 315-2 PN/DP has built in ethernetinterface. Siemens do not provide fetch/write functionality as if you use CP343-1 or CP443-1.
Siemens has already implemented this:
https://support.automation.siemens.com/WW/skm/frameset.asp?url=%2FWW%2Fllisapi%2Edll%2F23592043%3Ffunc%3Dll%26objId%3D23592043%26objaction%3Dcsopen%26siteid%3Dcseus%26aktprim%3D0%26skm%3D1%26lang%3Den&Query=communication+315%2D2&SearchArea=alle&id=23592043&F11Marker=false&siteid=cseus&query2=&modelled=&lang=en
But they charge you money for it.. *******s!
Has anyone out there already implemented this or any other tcp native protocol for reading/writing from/to the memory using s´7 315-2 PN/DP?
My task is to read/write some bytes in the send them to a PC.
Is there any particular reason to that you want to use Fetch/Write ?
You say that you want to send data to the PC (that is how I interpret your text). In that case Fetch/Write is the wrong choise. Fetch/Write means that the S7 PLC will respond to incoming datatransfer commands. The S7 PLC cannot itself initiate anything.
I can help you a bit, but I need to know the following:
What is it that you want to achieve functionally ?
What PC application (or kind of application) will communicate with the S7 PLC ?
Let's say I have an inverter fed three phase induction motor drive where in the braking phase (when the motor operates in a generator mode) the...
146
I want to improve a semi custom product I am delivering to a customer with implementation of safety relays. The system is fairly simple with just...
593
I'm struggling to implement the test case which is highlighted. What ends up happening is the servo starts when I turn the cycle on, but it...
1,076
I am trying to implement FIFO for filling tanks in the order it went empty in easysoft or some of you might know it by easydoft 7. I am trying to...
2,318
Dear friends, I'm using Mitsubishi FX3G PLC and GxWorks2 Software for programming. I need to implement 10 power X (X is a +/- floating value)...
1,073
