Importing a routine
This technote echoes the missing Import Configuration window and the hold down CTRL + SHIFT keys solution while starting RSLogix 5000...
562941 - Import Add-On Instructions crash RSLogix 5000
Access Level: Everyone
giajubo said:
...what did work for me was uninstalling every single version of RSLogix5000 I had installed (cries), installed them again...
I'll bet you did, and would again if you ever read the apparently simple solution!
p.s. Welcome to all those not welcomed in this thread, although some have not been back since.
Regards,
George
if you had a second monitor connected last time you had the file open, it is trying to display the import dialog window on the other monitor, which no longer exists. Plug in a second monitor and then drag the dialog window back to your primary monitor. This should fix it. It is annoying.
Hi syohannan & Welcome to the Forum!
The "hold CTRL + SHIFT keys" solution while starting RSLogix 5000 should reset the software to defaults. You "should" not require a second monitor to recovery from that scenario. I would try the reset first before fetching another monitor. Unless, of course, you are trying to avoid defaulting the software.
Stay Safe!
G.
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
500
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
381
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
622
Hi all, I am doing a side project where the HMI will play an mp4 file when a certain bit turns on when I toggle it from the PLC(384kb dig I/O)...
1,237
Long time member, first time poster. Last night our plants wireless network died, shutting the whole plant down. As a result, I have been tasked...
1,541
