Importing Add-Ons Backward Compactability in RSL5K
aradhonline
Nov 2009
Dubai
62
See friends .I have got a bunch of add-ons in the latest major version 19. But when i import and export this to the version 16 i am getting an error this R5L cannot be imported. I am sure from 16 onwards they have introduced add-ons and it allows to create inside it. Is there any workaround?
You mean Add-On Instructions ?
In general, RSLogix 5000 features are forward compatible, but not backward compatible. RA doesn't design new releases with the ability to automatically strip out, disable, or convert features to older designs.
I think that v16 still used a simplified proprietary text format for Import/Export, and that changed to XML in v17. That's just my recollection and may be incorrect, but it means that the Import/Export files probably have more than just a header value difference. You can check by opening them in a text editor.
In general if you are going to develop or share objects between multiple versions of RSLogix 5000, do your development in the earliest common version.
Hi! I am at my wits end and can't find any resources to help fix it so: I have a program I am importing from another computer that is WW2014...
18
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
505
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
385
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
623
Hi all, I am doing a side project where the HMI will play an mp4 file when a certain bit turns on when I toggle it from the PLC(384kb dig I/O)...
1,239
