Importing displays into RSView
lbaiguer
Jan 2008
Canada
After editing a working RSView 32 project on my laptop I copied the project on the run server only to have problem getting values from a direct connection to a SLC 5/04.
The question is what is the best way to edit a RSView project and then running it on the same station I copied the original one from.
In other words, you edited an RSView32 project on a laptop computer that was not connnected to the SAME communications driver as the original computer, so the Primary Communications Driver AUTOMATICALLY got reset to "None Loaded". Then when you load this copy back onto the original computer, it doesn't communicate with the PLC.
What is the best way to edit a RSView project and then running it on the same station I copied the original one from?
The best way is just as you did, except when the project has been reloaded onto the original computer, go to the "System" menu, then "Channel" and reset the Primary Communications Driver from "None Loaded" to the original driver. Then RSView will be able to communicate with the SLC 5/04.
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
498
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
379
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
621
Hi all, I am doing a side project where the HMI will play an mp4 file when a certain bit turns on when I toggle it from the PLC(384kb dig I/O)...
1,236
Long time member, first time poster. Last night our plants wireless network died, shutting the whole plant down. As a result, I have been tasked...
1,539
