Importing RSLogix5 Code
cavediver
Sep 2006
Barrie, Ontario
Quick question. I have received a few .RP1 files and need to be able to open them. I have RS500 and RS5000, but not 5. Is there a way to "convert" or "import" them into one of these two programs? At least even to view them??
Thanks in advance,
I don't think there is a way.
SLCs, PLC5s and Contrologix are all different PLC architectures, therefore, each has its own unique programming package
If you want to create a ControlLgix version of your application, RSLogix 5000 has a translation tool for importing SLC and PLC5 files and converting them but you'll need your PLC5 file in the .PC5 format.
If you just want to view it, post it here and one of us can PDF it for you.
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
497
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
375
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
618
Hi all, I am doing a side project where the HMI will play an mp4 file when a certain bit turns on when I toggle it from the PLC(384kb dig I/O)...
1,233
Long time member, first time poster. Last night our plants wireless network died, shutting the whole plant down. As a result, I have been tasked...
1,536
