Importing rung comments on RSLogix 5000
peludini
Jun 2017
Michigan
Hello,
I am working with Studio 5000 and due to uploading a controller with a file that was not updated, have lost the rung comments. Oddly enough it only happens in the Safety Task. The Main Task comments remain the same. An import/export would take care of my issue but, can I do this without having to unlock the safety processor and therefore changing its signature? I want to avoid that if there is a work around. The controller is a 1756-L73S GuardLogix5570 Rev 24.12, if that makes a difference. Thank you for any input!
Welcome to the forum!
I'm not sure of whether you can modify comments without safety unlocking or not - but one quick tip is that the 1756-L73S can store rung comments and other documentation in the controller, so that there are no such issues as this. In fact, they do that by default, so if they are not there, someone has deliberately chosen not to.
What I'm getting at is that if you DO have to unlock the safety PLC and generate a different signature in the end, you should make sure to download the comments into the PLC at the same time, so that you don't run across the same issue again.
Hey everyone, I'm working on a program for a SLC 5/05 controller using RSLogix500 v. 7.30.10 (CPR 9). We have a number of the same little...
14,863
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
497
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
621
Hi all, I am doing a side project where the HMI will play an mp4 file when a certain bit turns on when I toggle it from the PLC(384kb dig I/O)...
1,236
