Industrial UPS
Brijm
May 2006
St. Marys, PA
645
Can anyone reccommend an industrial UPS? We need a double conversion online UPS, to handle 3A 120V for a few minutes. We have a customer who is having power issues which is knocking out their burner control. We've used APC in the past for PLC projects, but their smallest unit that has full time power (no transfer time) is 1500VA, which is a bit overkill for this project.
Thanks,
We've had good luck with Sola UPS units - reliable, DIN rail mounting, and much higher temp tolerance than a typical office unit.
I like SOLA as well for smaller projects. Our BMS (4 of them) are backed up on a large APC unit. APC hasn't been real good for customer support or maintenance, though.
I used 3 solas on my last job. I needed 5va for 8 hrs l.they couldn't guarantee it because I was so far under the current spec. I got 13hr on a bench test.
Like Tom said din rail mounting.
You guy's sure the sola units are online double conversion?
I have never seen one that small that is din rail mount.
Most industrial geared are standby or Line interactive style.
I'm using the show symbol animation to open the pop-up and then the show content function to switch industrial graphics into the same window...
1,947
I am looking for the "right" type of industrial UPS but am not having much luck so far. The one feature I am looking for is a alarm output, no...
5,212
Hello, I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal...
22
2,263
Hey Everybody, I resigned from teaching, to pursue an IT career, and my original objective was to prepare for and pass a few entry level certs...
588
