Input Module Swapped Gender ?
TheWaterboy
May 2006
-27.9679796,153.419016
1,937
I just installed a 1769-IF4I and it refuses to read its input, instead showing a max value.
On the config page - Module Definition|Connection says "Output" and has no other options in the dropdown, whereas the 2 other 1969-IF4 I have in that same rack show "Connection" as "Input" with no other option to select.
Its happy in the IO tree, no caution sign.
Am I missing something simple?
Its live so I can't remove it to check for a while, but I finally got a reading by adding a jumper across the Neg and iRTN terms (like it says in the manual DOH!)
But the "OUTPUT" Connection remains. I'll post back when I get to shut it down again.
Mine does the same thing, but as you can see the IO tags look correct. This seems to be some of the typical bugs in RSLogix 5000, they never go back and fix the small stuff. So it keeps growing and growing.
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
124
In this sample programming, what does U4 mean? Any assistance would be greatly appreciated.
297
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
1,579
I have never understood how the I/O is configured using RIO. In the tree there is only the RIO module, not the racks of I/O attached or all the...
1,306
Hello Guys, Trying to scale a thermocouple directly into my IY4 card. Connected into the terminal +\-. I’ve scaled the range of my J type to...
1,691
