Input on one PLC; Output on another
Jim G.
Nov 2007
Georgia
187
I want to push a button going to one s7-1500 and have it turn on an output and turn on an output on another networked S7-1500. The local part is easy, it's the remote PLC that I am trying to get my head around. How can this be done? Please dumb it down for me as I am still relatively new to Siemens PLC's and TIA portal.
Thanks for the support.
Ok. That seems simple enough. For back and forth communication, does each PLC need a PUT block and a GET block?
If I want to communicate between more than 2 PLC's (Ex- 3 PLC's communicating with each other), does there have to be a GET/PUT combination for each PLC?
I have no idea; I'm just facile with The Google. Perhaps there is something written down? Like in a manual? Oh, somewhere?
If the two devices are on the same local network, look up I-Device in the help file. It lets the PLC pretend to be IO to up to 4 other controllers.
If there are multiples, it usually makes sense for 1 PLC to be the "server" and the others to all report to it. The server PLC can then route data between them as needed (it can do whatever you program it to do).
If you need true peer to peer, many to many type communication with no central point, then you could use the TSEND family of blocks to send multicast TCP back and forth. More complicated setup tho, for sure.
I looked more into my program. I have data blocks that are set up for communicating to a "main" PLC. This main can route data to the other PLC's in the line. In addition, the OEM set these blocks up with several "spare" structures I can make use of. This should work for me.
Hello everyone. I have a question about Rockwell PLC communication. Now I have a PLC5/30 and a Guardlogix 1756-L71S rack with 1756-DHRIO In my PLC...
1,422
I need one PLC to receive a signal from another PLC. Can I wire the PLC output of one PLC to the input of another PLC? (same voltage of...
3,943
Hey Guys, I am wondering if it is possible to wire an output from PLC to the start enable terminal (2) on the powerflex 40. as far as i can see...
1,697
Hello everyone I have a Siemens S7-300 CPU 315-2DP, CP343-2P and ASI module .AC2459 I want to using it for test input output . as show in below...
18
4,285
I have a question about overload protection for I/O modules 120v and 24v. I was curious to see is there any reason to protect a input considering...
3,330
