Insert data to SQL using wonderware archestra
joaco1993
Sep 2014
newyork
237
Hi everyone, I would like to know if there is a way to insert data to a SQL db using archestra wonderware. I have done this using intouch “standalone” by using the bind list and some scripting inside intouch.
I would like to know if there is a way to do this but using the archestra environment.. and using some objects. The data I need to store would be information about batchs. I will receive a bit when the batch is done and when I receive it I have to send data to 6 columns.
The reason I want to do it this way is because I don’t want to have open the window viewr in order to send the data. I want to be able to send without having it open. Perhaps using some scripting with the $winplatform or $appengine..
thanks for answering garry, it looks intresting, however this is using UDAs. I want to insert to sql values that i have in INTOUCH tags or PLC tags.. I could not find the way to see intouch tags in the application objects scripts..
Is there anyway to do this ? to pick tags from intouch and put them in objects scripts ??
thanks again
Hi
I don´t know if this can help you, but take a look to this sample of SQL with Archestra. It is spanish but the syntax of Script is the same.
Regards.
DBLD99:
I tried using intouch:intouchtag and didnt work.
I used it in an Appengine object instance and also in an Area object instance.
The intouch tag im trying to use is: PRUBA (boolean)
and in the appengine scripts or in the area scripts i wrote:
intouch:prueba=1 , script on scan , and also tried excecute and didnt work..
any ideas ??
thanks
DBLD99:
any ideas ??
thanks
edit: I think what you meant was in the graphics objects..
Microsoft SQL querys from ArchestrA script.
I use ODBC because it is portable from one pc to another. I just use custom property tags filled in with the ---. As an example "MachineTime" is a custom property. I also use Visual Studio 2010 Visual Basic to debug the code that runs in ArchestrA scripts. You just need to add the ; at the end of the statement. Also there is no using clause so the entire class name must be used.
Here is a sample that uses stored procedures to send data to a database table. This is the script that could go in a symbol script or a button script.
Dim myReader As System.Data.Odbc.OdbcDataReader;
Dim sConnString As String;
Dim oODBCConnection As System.Data.Odbc.OdbcConnection;
Dim oODBCCommand As System.Data.Odbc.OdbcCommand;
LogMessage("ODBC PutData");
sConnString = "Dsn=MyODBC;Trusted_Connection=Yes;";
oODBCConnection = New System.Data.Odbc.OdbcConnection(sConnString);
oODBCCommand = New System.Data.Odbc.OdbcCommand("{ Call PutData(?,?,?,?,?,?,?,?,?) }");
oODBCCommand.CommandType = System.Data.CommandType.StoredProcedure;
oODBCCommand.Connection = oODBCConnection;
Dim Machine As System.Data.Odbc.OdbcParameter;
Machine = oODBCCommand.Parameters.Add("@Machine", System.Data.Odbc.OdbcType.Int);
Machine.Value = MachineTime;
Machine.Direction = System.Data.ParameterDirection.Input;
Dim HydraulicPump As System.Data.Odbc.OdbcParameter;
HydraulicPump = oODBCCommand.Parameters.Add("@HydraulicPump", System.Data.Odbc.OdbcType.Int);
HydraulicPump.Value = PumpTime;
HydraulicPump.Direction = System.Data.ParameterDirection.Input;
Dim Extruder As System.Data.Odbc.OdbcParameter;
Extruder = oODBCCommand.Parameters.Add("@Extruder", System.Data.Odbc.OdbcType.Int);
Extruder.Value = ExtruderTime;
Extruder.Direction = System.Data.ParameterDirection.Input;
Dim Lube As System.Data.Odbc.OdbcParameter;
Lube = oODBCCommand.Parameters.Add("@Lube", System.Data.Odbc.OdbcType.Int);
Lube.Value = LubeCycle;
Lube.Direction = System.Data.ParameterDirection.Input;
Dim Maint24 As System.Data.Odbc.OdbcParameter;
Maint24 = oODBCCommand.Parameters.Add("@Maint24Time", System.Data.Odbc.OdbcType.Int);
Maint24.Value = Maint24Time;
Maint24.Direction = System.Data.ParameterDirection.Input;
Dim Maint120 As System.Data.Odbc.OdbcParameter;
Maint120 = oODBCCommand.Parameters.Add("@Maint120Time", System.Data.Odbc.OdbcType.Int);
Maint120.Value = Maint120Time;
Maint120.Direction = System.Data.ParameterDirection.Input;
Dim Maint480 As System.Data.Odbc.OdbcParameter;
Maint480 = oODBCCommand.Parameters.Add("@Maint480Time", System.Data.Odbc.OdbcType.Int);
Maint480.Value = Maint480Time;
Maint480.Direction = System.Data.ParameterDirection.Input;
Dim Maint2400 As System.Data.Odbc.OdbcParameter;
Maint2400 = oODBCCommand.Parameters.Add("@Maint2400Time", System.Data.Odbc.OdbcType.Int);
Maint2400.Value = Maint2400Time;
Maint2400.Direction = System.Data.ParameterDirection.Input;
Dim Maint4800 As System.Data.Odbc.OdbcParameter;
Maint4800 = oODBCCommand.Parameters.Add("@Maint4800Time", System.Data.Odbc.OdbcType.Int);
Maint4800.Value = Maint4800Time;
Maint4800.Direction = System.Data.ParameterDirection.Input;
oODBCConnection.Open();
MyReader = oODBCCommand.ExecuteReader();
MyReader.Close();
oODBCConnection.Close();
Here is the stored procedure
USE [MyDatabase]
GO
/****** Object: StoredProcedure [dbo].[PutData] Script Date: 03/08/2016 11:41:35 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
-- Author: <Author,,Name>
-- Create date: <Create Date,,>
-- Description: <Description,,>
CREATE PROCEDURE [dbo].[PutData]
-- Add the parameters for the stored procedure here
@Machine int,
@HydraulicPump int,
@Extruder int,
@Lube int,
@Maint24Time int,
@Maint120Time int,
@Maint480Time int,
@Maint2400Time int,
@Maint4800Time int
AS
BEGIN
-- SET NOCOUNT ON added to prevent extra result sets from
-- interfering with SELECT statements.
SET NOCOUNT ON;
-- Update statements for procedure here
UPDATE MyDatabase.dbo.Timers SET [Machine] = @Machine, [HydraulicPump] = @HydraulicPump, [Extruder] = @Extruder, [Lube] = @Lube, [Maint24Time] = @Maint24Time, [Maint120Time] = @Maint120Time, [Maint480Time] = @Maint480Time, [Maint2400Time] = @Maint2400Time, [Maint4800Time] = @Maint4800Time WHERE DataId = 1
END
This table only has one row but you can use an INSERT IGNORE INTO for more rows. ArchestrA 10.0 needs to have an invisible graphic on screen. I use a hidden rectangle. :)
Thanks everyone for answering..
Trevieze, that would work yes, but i would have to have the intouch viewer opened..
I want to find a way of inserting data into sql from the Appengine Or Area objects, so there is no need to have it open ( the viewer ).
Why ? supose there is a batch running or any process and at that time i need to do some changes in the scada which is sending the data to SQL. I would miss some information during the time i am doing changes and not deployed the new app.
If I can do it using the Appengine object or any other object that i could put scripting ON SCAN or execute, then there would be no need to have the intouch viewer opened.
thanks again
In application server, you do not use InTouch:IntouchTagName to link to intouch tags. You must use the absolute refernence <$InTouchViewApp instance name>:InTouchTagName. This is because Application Server may host many intouch client applications so you have to specify which one to connect to in order to read tags. InTouch:InTouchTagName can be used in archestra graphics as "InTouch:" refers to its hosting InTouch application which is a relative reference.
The Intouch application must still be active on the client though so I'm not sure if this will work for your application.
Hi All, I need a step-by-step method to insert and update lines in the database SQL Server via software builded in FT View SE. Thanks. Fabricio
60
18,847
Hello, Have a problem with the insert statement in vb.net 2010 with sql server, have my table but it keeps give me an error, attached table and...
1,340
Is it possible to make I/O filed on HMI of POINTER data type? Pointer data type can be either temp, IN or IN_OUT variable inside FB. it would be...
1,784
I'm new to ST so go easy. Studio 5000 L33ER PLC I'm trying to take 2 strings, merge them into 1 string. with a space between the 2 strings...
2,258
Hello everyone. Currently I am using Eplan p8 and faced (while creating a panel) with a challenge in finding a device called DIN mounting rail...
3,438
