installing factory talk without a key
robw53
Nov 2009
south yorks
515
i have a legit copy of factory talk view studio and i wondered if there was anyway of been able to install on a second computer without buying a second key? ive hurd a member talk about been able to get around the key part with the floppy disks
rob
You can install the s/w on multiple computers but only one copy of the s/w can be running at any one time and you can do that by moving the activation to a floppy disk or memory stick and having it connected to the computer that you wish to run the s/w on. There are meny There are several tech notes on this topic at Rockwell's Knowledgebase.
You may have a legit copy, but if you want to run the s/w on two machines, then you need two legit copies. Otherwise, as mentioned above, you will need to look at moving the license back and forth or hosting the license on a "license server".
OG
Hello Everyone, I just upgraded my FTV so that I can do SE projects. I have been able to download Version 8.20 without a problem. When I go to...
19
21,393
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
105
During the process of installing Studio 5000 Mini Edition to my new machine at work, it seems as though some things like RSLinx Classic and the...
574
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
732
Hi all, I tried to install Twidosuite on windows 10 but after installing i have the registration link which is not working and also i get with...
583
