instrument/electrical test
kirby36
Feb 2003
hi,
I am applying to a job which requires a test to be passed. I was told it will be based on electronic and instrumentation. I am not new to the field, however i have never taken a test on instrumentation. I need help on what to exactly study for it.
Hurry!
You may be a little late on preparation for this job, but here is a partial list of things you need to know. Others on this forum will undoubtedly have more to offer.
1. Bone up on basic sensors, i.e. Thermocouples, RTDs, pressure sensors, load cells, flow meters, etc. Good online sources for finding information so use your favorite search engine.
2. Controllers, basic function, PID, On-Off, and Time proportioning control technique. Input/Output standards such as 4-20ma, 0-10V, frequency. DCS, PLC or single loop.
3. Calibration of equipment: Zero and Span, types of calibration equipment, i.e. current calibrators, RTD and Thermocouple replacers.
Pressure and temperature calibration requirements.
4. Loop tuning manually in case you do not have auto tune and even if you do, what is the best method. Ziegler-Nichols method, trial and error, what is quickest to do.
As I said, this is only a partial list that is on top of my head at the moment, but there are other things to consider.
Hi all, Looking for a temperature sensing solution for determining ambient temperature in the frigid Canadian winters. Discrete outputs are fine...
1,508
I was tasked with putting together equipment for a mobile temperature monitoring system for our oil rail cars. Apparently, the crew that unloads...
840
Hello, I have a question regarding instrument cable. I know that for 4-20ma transmitters twisted pair cable should be used with the screen...
2,257
Hello, We have a 6es7 32101BL00-0AA0 DI card. There is a level switch to be added from an E&H FMR62. Our client is of the opinion that as the...
1,255
I was wondering if anyone had an success finding a Database driven managment program that can save&print all the following...
2,268
