Integer arithmetic, no decimalpoint
Thanks everyone.
After searching around alot I found an algorithm that adds the modulus/remainer of the previous calculation to the regulator output.
Code:
error[0] := setpoint - measure;
up := (Kp  * (error[0] - error[1])) / K;
ui := (Kp * error[0] + ui_mod[1]) / ((Ti*K)/Ts);
ui_mod[0] := (Kp * error[0] + ui_mod[1]) MOD((Ti*K)/Ts);
u[0] := u[1] + up + ui; (* Output *)
u[1] := u[0]; (* Prev. output *)
ui_mod[1] := ui_mod[0]; (* Prev remainder *)
error[1] := error[0]; (* Prev error *)
Doing this I ended up without a stationary error, whats the logic behind this algorithm?
Does anyone know of any such PLCs? Usually I'm lazy and don't want to think about precision and overflows.
20
6,986
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
432
Good morning all, I'm integerating a device with a Rockwell PLC with V34 Studio 5000. The device reports error codes using a single integer to...
19
1,291
Ex If I Read from Integer file N7:0 N7:0 is an 8 point input card , input 0 and 2 are on , rest off When I look at : N7:0 -7 6 5 4 3 2 1 0 I...
746
The analog array has 16 individual bits and each bit is an alarm. SCADA is having issues getting the BIT bool value. However they can get the...
1,022
