Interface 1761-NET-ENI problem
manasi
May 2007
maharashtra
123
Dear All
I am trying to connect micro logix 1200 on ethernet. For that i am using 1761-NET-ENI series-D. I have downloaded new ip address to ENI-ROM. Now link LED is green and fault LED is off. But when I browse the network in RSlinx classic with ethernet driver it shows unrecongined device.
Please advise me the exact procedure of ip configuration.
I want to assign ip to ENI is 192.168.0.16 and sub net mask as 255.255.255.0
Thanks & regards
Manasi
If the RSLinx browse shows only a yellow question mark, then all you need to do is download and register the Electronic Data Sheet for the 1761-NET-ENI/D. This is a file that informs RSLinx about the device, including what little icon to display and how to route messages through it.
You can search the RA EDS database, or just download the file directly from this link:
http://www.ab.com/networks/eds/cgi-bin/detail.pl?file=EN/0001000C00630300.eds
Use the RSLinx Hardware Installation Tool to register the EDS file. Start -> Programs -> Rockwell Software -> RSLinx -> Tools -> RSLinx Hardware Installation Tool.
If RSLinx shows a yellow question mark with a red X over it, then RSLinx can't communicate with the 1761-NET-ENI at all and you have a more fundamental problem with your PC and the -ENI's IP addresses and subnet masks.
When you install new versions of RSLinx, a database full of EDS files is installed too. That's why the solution to missing EDS files is often to update RSLinx Classic. It's easier and faster to just install the one EDS file in this case.
NET ENI problem
Make sure the NET-ENI has a fixed baud rate and the channel 0 port is set to full duplex with matching parameters (baud, protocol, error checking, etc...).
I'd like to add a PLC-5/20 to our existing ethernet network, this seems like an economical solution. I'm only needing to view and modify ladder...
2,643
Dear, I have to communicate my SLC 5/04 CPU channel0 ,configured as DH485, i have an ethernet interface 1761 NET ENIW. I have read how to...
3,926
I have a 1761-net-ini connected to a slc504. I have been talking to it wireless over a bridge, for about a year. The wireless is very unstable, so...
2,290
I have two location. Location 1 has a VT-Modem-1 connected to a MLGX 1200. Confirmed to be working by connecting from offsite locatoin. Second...
1,636
Has anyone used the AB 1761-Net-ENI module which is connected to a Micologic 1500 and talking to Wonderware Intouch ver 8.0 using DA Server ABCIP...
2,376
