Im sorry for incomplete circuit, I have also supplied 5V to the collector and across one side of the relay coil.
This doesn't make sense.
[In your drawing], you would only want to supply +5VDC to the top relay terminal, or non arrow side of each diode.
If you supply +5VDC to the transistor collector as well, the CE junction is short circuited across the 5VDC supply,
whenever the PLC output contacts close.
