Interfacing dc motor with s7-200
Im sorry for incomplete circuit, I have also supplied 5V to the collector and across one side of the relay coil.
This doesn't make sense.
[In your drawing], you would only want to supply +5VDC to the top relay terminal, or non arrow side of each diode.
If you supply +5VDC to the transistor collector as well, the CE junction is short circuited across the 5VDC supply,
whenever the PLC output contacts close.
Yes indeed. That is right out of the textbook for creating a switching transistor circuit:
Basic NPN Transistor Switching Circuit
I have a Cognex Insight 2000-130 camera that I'm trying to get talking to my PLC. Both are connected to the same router via Ethernet. Thus far...
1,323
Hi, I am picking up a project started by a predecessor who is now out of contact. It is a Siemens S7-1515F PLC system - but the query is how you...
770
Hi everyone, I've got to interface 4 x Mitsubishi Q series PLC's with an Allen Bradley Compact Logix PLC using a Red Lion Data Station DSPLE000...
526
hello i want to read temperature data from Masibus UT94 temperature transmitter which is giving data on RS485 port. i have assigned ID:-30 and...
1,075
Hello I am very familiar with ladder logic and PLC programming, however I am new to Allen Bradley, ethernetIP, and interfacing measurement...
1,062
