InTouch 9.5 ActiveX problem
Inna
May 2007
Tel_aviv
I'm developing an application in Intouch 9.5(Version 9.5.003). I came up against two serious problems and I would like to receive some help.
The first one is:
ActiveX (that was developed in VisualC++ 6.0) is used in this application. Sometimes the next problem happens: when the application is opened in the WindowMaker, the ActiveX appears on a screen normally (without any problem). But when I run the application the following error message is displayed:"0x100e0202 Error processing on setting real property (param) Button.Visible OLE object reference is not bound to an OLE object" - where "Button" it's name of the ActiveX.
I found the following workaround to prevent this error:
A new ActiveX is added to an application's screen with ActiveX. The application is run and there is no problems with any ActiveX. After this, the new added ActiveX is removed and the application is running properly.
Mostly, this problem occurs when the application is run first time after ActiveX registration on the PC.
The second problem is:
When the InTouch application is running the CPU Usage of the view.exe is more than 60% - it slows down the performance of our system.
What could be the reason of these problems? How they can be solved without workaround (for final user)?
There are a couple tech notes on Wonderware's website that talks about "fixing" activex problems. Try them first. Also try recompiling the application by deleting the *.wvw files. what sort of activex are you using? There are lots of poorly written activex out there.
The first one is:
I know it's a really old post, but I'm having the same issues and I wanted to know how you solved it.
Thank you.
Hi everyone! I'm currently creating a window in Wonderware InTouch (WindowMaker) and I'm trying to implement a common dialog control. I select...
5,172
Hi, According to InTouch manuals, this is how to install ActiveX: And this is how it appears on my computer: The "ActiveX Control...
5,527
I found a Color Picker and it has some demo script to set the InTouch Window to the color selected from a button actions script. It works but I'd...
937
I am trying to integrate a RTSP video stream into a Wonderware InTouch application, without success. The computer is running a 64 bit Windows 10...
2,902
Hello Experts and everyone, I hope everyone is safe in these hard times. As for me, the work still continues on the field. I need help with our...
1,565
