Intouch and opc
catalin78
Feb 2005
Constanta
115
Hello !
i have to make some new screens in a intouch visualisation system wich runs on two computers , it works with opc server and as i seen opc is getting data from 3 hardware (PLC s7-400 ,Some ET200m).
Because intouch visu is runnig on two computers i can start my practice on one of these computers .
First i need a hint to a software wich i can use to backup as a image all things that are in that pc , so i can't damage something .
Second i need some links or places where i can get info on this intouch sistem wich i need to practice and learn and opc server .
Between plc and et modules is a profibus network , and a ethernet between plc and computers with intouch visu .
I have source of visu and plc program , and i have installed intouch 9.0
Also i have experience on s7 manager , wincc flex .
I kindly thank all of you for your time on this matter .
For now that's all the info have from the site because i am in vacantion , but next days i can know more if it's useful .
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
196
hi everyone, i am working on OPC factory server with Wonderware InTouch, in intouch view all the parameters (feed back) of instruments and pump...
2,001
Friends as the heading shows i want to integrate rslogix 500 with rsemulate 500 and rslinx opc server with fsgateway to see data in intouch...
2,113
Does anyone know if FS Gateway has a limitation of number of tags? I was told that it has (up to 25k I/O tags), but I can't find any document...
2,843
Hello, Does InTouch got an OPC client? Or do I need to install a OPC client to be able to communicate with an Matrikon OPC Server? Regards Raffe
2,056
