OPC factory server with Intouch
kaareem
Feb 2018
india
56
hi everyone, i am working on OPC factory server with Wonderware InTouch, in intouch view all the parameters (feed back) of instruments and pump are there and i can read through OPC also, my issue is i can run some pumps and some pumps unable to run, it is giving X marks on buttons which can be seen in following picture, the pumps which i can run are on different location with different RTU (TBOX), and the pumps which i can't run are on different location with different RTU (M340)
The OPC reading all feed back but not executing (M340) Pumps, all the pumps are on auto mode in local panel
please suggest me to run these pumps also, thanks all of you
Red X on graphics indicates bad data quality for the tag. You'll need to figure out if this is OFS unable to communicate to the device, or InTouch unable to communicate to OFS. Since OFS is an OPC server and InTouch does not have a native OPC client, you likely are using OI Gateway or FSGateway in the System Management Console to do the Suitelink to OPC conversion. Gateway has a diagnostics view which you can also use to check on the tag quality.
Since some work and some do not, my bet is that OFS is not connecting to the device for some reason.
Has anyone ever used Schneider's OPC Factory Server with Rockwell's FTview SE Local station before? I'm using a Schneider 416NHM30042A Modbus Plus...
1,512
Looking for an OPC-Client that can be used for logging data and displaying trends on a display on the factory floor. Ideally a Redlion PTv with...
2,791
**Edit, ok I think that the OFS simulator is, well, a simulator so doesn't actually connect to the PLC, weird that I can get the tags from the PLC...
2,822
Hi, Can the FT Historian SE catch and store data from an OPC Server like Matrikon? If so, Would the FT Historian take the timestamps directly...
2,880
Dear all, I working on a project for monitoring substations installed in our underground mine. We have like 25 to 30 RS485 Energy meters. Is...
2,657
