InTouch from InSql
rrangaprasad
Feb 2005
28
Trying to have some of my intouch nodes read (no writes)values from InSql (as they cant access the tag server). So using aahiosvrsvc.
ISSUE: aahIOSvrSvc doesn't update some tags. This is random everytime. Sometime, i get some values, but they are OLD and they dont change.
WORKAROUND i got from techsupport:
In a script on startup, write for each tag that you have historized by insql, tag = tag. It just needs to be executed one time.
tag=tag gives me error in the historian log, as it is not permitted to write values to the Historian from Client.
Its ok. Evn then, as soon as i execute the tag=tag script (i have it in a button), BOOM, the values gets updated. However, the update is almost a one-shot. Any updates after this is not shown, even when i click the button (with tag=tag script) again.
Just curious as to difference between tag=tag and re-initialize all, as re-initialize all does do the trick
I do not want to be doing tag=tag for 1000s of tag.
Any help appreciated.
THANKS
Hello All, I am trying to connect to a server using Distributed Name Manager and assigning InSQL Provider for trending purposes. I've set up the...
3,127
I am creating a test application, (wonderware 9.5) for display only purposes that will display data from over 20 PLC's. Rather than configure a...
2,805
Anyone, On how to configure Intouch to show server_fail pop-up from the SysPulse from InSQL. How to write a script for that and develop tags...
2,216
I want to set up tags in Intouch that will connect to the system monitor tags within InSQL to monitor the status of the system (running...
5,456
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
