Hello All,
I am trying to connect to a server using Distributed Name Manager and assigning InSQL Provider for trending purposes. I've set up the below popup with proper info.
When I pressed Test, everything is ok. I can ping the server and the server can also see me with no issues. However, I am getting:
DB-LIBRARY ERROR: Unable to connect: SQL Server is unavailable or does not exist. Unable to connect: SQL Server does not exist or network access denied.
Operating-System Error: ConnectionOpen(Connect())
Is anyone familiar with this issue? It says it is possibel that network access denied. How exactly?
Thank you in advanced,
