Wonderware InTouch 9.5 InSQL Provider Not Connecting to Server
Grendizer
Apr 2012
Toronto
88
Hello All,
I am trying to connect to a server using Distributed Name Manager and assigning InSQL Provider for trending purposes. I've set up the below popup with proper info.
When I pressed Test, everything is ok. I can ping the server and the server can also see me with no issues. However, I am getting:
DB-LIBRARY ERROR: Unable to connect: SQL Server is unavailable or does not exist. Unable to connect: SQL Server does not exist or network access denied.
Operating-System Error: ConnectionOpen(Connect())
Is anyone familiar with this issue? It says it is possibel that network access denied. How exactly?
Thank you in advanced,
I want to set up tags in Intouch that will connect to the system monitor tags within InSQL to monitor the status of the system (running...
5,484
196
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
192
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
482
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
221
