IntouchV8 to L1400 via ABTCP
Yes, although you might investigate installing a more modern I/O server such as the DASABCIP from Wonderware.
For the new processor you may create a new Access Name using the new I/O server in Windowmaker and assign your new tags to it.
Thank you for your response. I have assumed it would require an upgrade to WW Intouch V10 to use DASABCIP[V4.1 I think] with the L1400. However it is good to know the L1400 will accept ABTCP. thanks again
Actually, I was referring to using 2 separate I/O servers within the same application, I shouldn't have said that the AB Micrologix 1400 is supported with ABTCP, because I'm pretty sure it's not! My mistake!
You can use the DASABCIP driver with no problem (I think) in Intouch 8.0, it doesn't care. All it should need is a DDE/Suitelink Topic.
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
517
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,449
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,232
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,838
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
848
