Inverter suitable for Canada
Johnny T
Jul 2003
Fife, Scotland
642
I'm after getting hold of an inverter in the UK suitable for a job that's being shipped to Canada.
The inverter has to be fed by single phase (110V - I believe...).
I've tried Omron but got no joy and also ABB.
I just wondered if anyone has any recommendations or anything I need to watch out for as the job needs to be tested here in the UK before going out to Canada.
Cheers
JT :)
Find out the power and voltage requirements and then try here.
Many AC drives will accept single phase input, but must be derated...check the manual for whatever drive you choose.
Hi John,
Siemens do a Micromaster 410 that can be fed with 100..120VAC 1ph
The power range available is only 0.12kW to 0.75kW though...
Kevin
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
82
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
511
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hello I am writing to request assistance with obtaining a specific GSD file for our Mitsubishi inverter type A800-E, which is connected to our...
429
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
204
