Inview Message Display
robw53
Nov 2009
south yorks
515
I have an inview text display and im wondering if you can have two variable fields on the same display or not, i have tried this and failed! i dont think you can as you only have one variable word but thought someone out there would no for sure.
SLC 5/04 with NET-ENI
2706-P42R - DISPLAY
2706-PENETP - ETHERNET ADAPTOR
Im wanting to display stoppage time for todays shift and the previous shift, im using the examples from the inview software i can update the variable but struggled to get the text display to change, i was testing it first on a compact logix as we had one in the workshop, but now i will be fitting it to the line and just wanted to see if anybody had any tips from past experience with these.
i have looked over the advanced folder that came with the IMS software and can see that you can have multiple variables, the example shows using a 5/05 on ethernet but i will be using a 5/04 with a net-eni so would i need to write ascii out of the serial port or would i still program it as the example?
I am trying to set up an InView display (2706-P42R-SC) with an ethernet communications adapter (2706-PENETM). I was able to connect to the...
3,783
I have a facility with an Allen Bradley InView Marquee Message display and I would like to upload the program that is in it. Can anyone tell me...
6,405
Can Modicon Quantum PLC communicate and drive the AB's InView Message Display over the Ethernet protocol? How to write the ladder logic for it...
3,309
Has anyone managed to communicate to a Inview display from a GuardPlc. Even through a intermediatary PLC. The Inviews are on ethernet network and...
4,251
Hi everybody: I am trying to set up an ENI for an Inview message board, so I can get the message board onto my factory Ethernet. I need to...
10,840
