ENI - Inview message display configuration
Daggi
Apr 2003
Hi everybody:
I am trying to set up an ENI for an Inview message board, so I can get the message board onto my factory Ethernet. I need to trigger message on the Inview by sending messages from an SLC 5/05.
I used the ENI utility to download my ENI settings:
- deselected BootNP
- assigned IP address and subnet mask
- seleted 9600 as RS232 baud rate
- message routing: seleted destination 1 and assigned IP for my SLC 5/05 which will communicate with the ENI/Inview)
- utility settings: selected COMM 1 and baud rate 9600)
The download of these setting worked okay once I made sure that RSLinx was shut-down. However, when I later connected my computer to the Ethernet network by plugging into a hub and configured my Ethernet driver including the ENI, RSLinx could sometimes see the ENI for a little bit and then it lost it again.
I was asked to download RSLinx evrsion 2.41 to get rid of this problem, however, after installing the new software, I completely 'lost' the ENI.
RSLinx shows the IP address of the ENI now with a red cross.
I can still ping the ENI, but cannot see it in RSWho.
The PLC program running on the SLC 5/05 show in the message windows, that the PLC tried to send a message, however, an error occured (timed-out).
Can anybody help me with this problem? how do I get the ENI working in RSLinx?
Any help is appreciated.
Daggi :confused:
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
143
Good afternoon guys, does anyone recommend a direct replacement part for Allen Bradley's 1761-NET-ENI devices? We have a lot of these in our plant...
1,006
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
930
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,791
I have a simple question I’m kinda embarrassed to ask. If I have a micrologix 1500 on a net eni. Can I replace my Ethernet switch with a WiFi...
1,411
