IP address Conflict
peng
Sep 2005
Chicago
48
We have a bunch of Ethernet addresses that were distributed to number of techs to use at our company.
subnet mak 255.255.255.0 (IP. 225.0.8.55,56,57,etc.)
One of techs went to use his given address, when he went to configure and use it, he gets a message that perticular address is used. I know for the fact that perticular address is not used any where. How can we find out where the conflict is?
I did
I did try that and it times out (request times out), and when try to connect it says there is a conflict or been used.
You can unplug things at the central switch (or distributed switches) until there is no conflict to isolate the duplicate.
If you have managed switches, you can usually query the switch to see what IP's it sees on each port.
Are you absolutely certain the address isn't used? Not all devices respond to ping requests.
What other configuration options are present on your network? BOOTP? DHCP?
Does the computer have a wireless and wired connection? They shouldn't be set to the same address if so.
How many network adapters show up in the network configuation on the computer? How are they set up? Does anybody have alternate IP's configured ?
Some routers have what is called static DHCP. This is where you can tell the router to issue a device with a specific MAC address a certain specified ip address. This would basically prevent the router from issuing that ip address to any other device. This allows you to set up a device to use DHCP, and still get the same ip address every time it is powered up. This is usually done when the router needs to port forward to a specific ip address.
I am not sure if this would cause a "address conflict error" or not, but it might be something to check in to.
122
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
201
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
100
Hi Guys, Is it okay to have Redundancy ControlLogix Processor IP address set to DHCP? I had Static IP address on it but removed it via RSLinx...
241
Hi everybody, I have DELTA PLC DVP-32ES and I have make a simple project in WPLSoft. using the input X0 to switch ON the output Y0 and using the...
179
