IP Addressing and RSLinx
Tim Ledwith
Nov 2003
Mackay, QLD
90
I was setting up Ethernet communications at a Customer site recently in preperation for going online to a 1761-NET-ENI module.
The IP Address I was given was 10.29.123.065, but when I entered this into the Ethernet Devices setup (AB_ETH-1) in RS Linx I ended up being connected to the PLC at IP Address 10.29.123.53. When I entered the IP address as 10.29.123.65 (minus the leading zero in the last number) I connected to the ENI module.
I'm assuming this is some kind of Octal/Decimal thing (65o = 53d) because when I experimented with some other numbers, the same thing happened.
I'm using RSLinx Gateway verson 2.43.01.23 (CPR6).
Has anyone else had the same thing happen to them ?
Thanks, Tim.
In every program 0 before IP means Octal - Windows works like this, Linx and Logix work like this
But for some stupid reason NET-ENI does not, they display this 0s while it is still in decimal format.
You actually entered 010.029.123.065 in NET-ENI
i guys another question for you, i have quite a few allen bradley plc on our machine's and they all have different ip addresss what i am asking is...
23
27,015
I am very new to Modbus and the industry, so forgive me if I am missing something obvious. I have known Modbus register addresses coming from a...
238
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
393
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
286
Hello all. I have a Simatic SM374 (374-sxh01-0aa0) sim module. I am using TIA portal v.18. I can't find this module in my list of hardware devices...
763
