ip config
Hojland
Oct 2006
Langå
203
Hey Guys.
I have to change some ip adresses. One in a SLC and one in a panelview 1200. If i change the ip adresse in the SLC in channel config and the ip adresse on the panelview, how do they know that they must talk to each other.
They just know because they like each other.
I am guessing here that you are talking about a 505 and a plus.
There are 2 ways to do it. In the plus go into the rslinx configuration and manually reset the old ip address to the new address. Scroll down to the old IP address and then click on the edit button.
The other way to do it is modify the original APA code and repoint to the new IP address. Make sure you copy the shortcut to the target. After that you will need to upload the after creating the new MER file.
Hey. I have tryed the first poseblity. I works great. But when the power is taking away from the plus, it forgets the new(plc)Ip adresse again. Can I save it somwhere in the plus
Mark - you're the man! I'm amazed that you got that:
Out of that:
Hey Guys.
Question:
Answer - already supplied:
Wild guess here but....
When you assign an IP address to your sLC, make sure that you disable the BOOT TP and also DHCP options.
After that, the IP address of your SLC will be "fixed".
Once your PV comms setup is set to look for that address, you'll never have to change anything again.
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
88
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
222
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
87
Hi everyone, I’m trying to copy the configuration from one MVI69-MCM to another. I am having no luck establishing serial comms with the device...
94
I have 3 new PowerFlex 7000 VFD's. Rockwell was out to do some checking before startup. These are part of a larger electrical project. I gave the...
342
