Is it possible to add more RS232 or RS485 ports on Control Logix plat-form
bundhit
Sep 2003
Bangkok
39
My system has 5-6 weight indicators including with RS232 or
RS485 port. I would like to communicate these weight indicators
via the control logix CPU (1756-L1M1). What the communcation cards
shall be used.
I've never seen one but I have seen little black boxes that convert Ascii to TCP/IP and will drop it exactly where you want it to go and each one supports 2 serial devices. I've only used them for barcode scanners.
I will try to get a link sometime if you are interested.
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
357
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
235
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
187
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
833
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
295
